10-10-2014 06:29 AM - edited 03-07-2019 09:03 PM
I have two 3750 as core switch (no Stack) and two C2960S FlexStack , I config Etherchanel between 3750 (both Po6) and C2960S (Po1,Po2), I use protocol lacp
I "Show Etherchanel Sum"
C2960S
Po1 Gi1/0/25 (P),Gi1/0/26 (D)
Po2 Gi2/0/49 (P),Gi2/0/50 (D)
3750 (Swtich1)
Po6 Gi1/0/9 (P),Gi1/0/10 (D)
3750 (Switch2)
in show command can use 1 port and down 1 port
can help me ?
regards
myfeel
10-10-2014 06:55 AM
Post the config of each interface and also the config of your port channel
10-10-2014 07:19 AM
Hi Micahel
3750 (Switch1) config interface
interface Port-channel6
switchport mode trunk
interface GigabitEthernet1/0/9
channel-protocol lacp
channel-group 6 mode active
interface GigabitEthernet1/0/10
3750 (Switch2) config interface
c2960S config interface
interface Port-channel1
interface Port-channel2
interface GigabitEthernet1/0/25
channel-group 1 mode passive
interface GigabitEthernet1/0/26
interface GigabitEthernet2/0/49
channel-group 2 mode passive
interface GigabitEthernet2/0/50
10-10-2014 07:29 AM
Try removing channel-protocol lacp from your interface configs and see if that helps.
