3750 pumping error messege.
Hi Team,
               I was configuring 3750 stack, I am supposed to run bgp on it. after making a VLAN , i got an err messege as below.
PSECURE: Assert failure: 0: ../switch/psecure/psecure_ifc.c: 291: psecure_get_vlanid
-Traceback= 7BCADC 7C149C 7BA8DC 7BECA0 757B90 767D5C 3516E8 C65FF4 C82214 9A5850 99CE24
I am using ios version version 12.2(35)SE5
could some one please help me on this, whether this will affect switch functionality.
Sreekanth V.S
5 Replies 5
Peter Paluch
Sreekanth,
It is hard to tell. An "assert" is a general term in programming, and it is a verification deliberately inserted into code to verify for sanity and consistency of the internal variables - whether they are set, whether they contain sensible values, and so on. An "assert failure" means that such check at some point of the code was not successful - essentially indicating an error either in the code or in the data that are processed by the code - in both cases, a possible bug. Whether the code can recover from this failure cannot be said in general.
I strongly suggest upgrading your IOS to a newer version - your IOS is quite outdated - and repeating the procedure.
Best regards,
Peter
Thanks Peter for the swift reply.
Could you please let me know the stable release for 3750 . I am looking for a ipservice image.
Shashank Singh
Hi Sreekanth,
It is pretty likely that the error messages are because of a cosmetic bug documented at http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsg93413
This bug has been fixed in IOS version 12.2(37)SE and later.
12.2.55-SE1 the latest IOS version available for 3750 platform which contains maximum number of bug fixes, and is stable.
Cheers,
Shashank
Please rate this answer if you found the content useful
I have seen a strange behaviour when i ping from my FWSM to 3750E switch. The switch is reachable from fwsm but after every 1025 nos of ping a time out is occuring, what could be the problem. Kindly find the details below
FWSM/external# ping 192.168.1.2rep 2050
Sending 2050, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 99 percent (2048/2050), round-trip min/avg/max = 1/1/20 ms
andtoth
Level 4
Level 4
You are most likely hitting a software defect with id CSCsg93413.
In certain cases, a cisco device may display a message such as the following shortly after the boot process completes:
This message may be accompanied by tracebacks.
There is no known workaround.
Please refer to the Bug Toolkit page for more information about this defect on the following link:
This has been fixed in 12.2(37)SE, however I would recommend you to upgrade to the latest IOS version which is 12.2(55)SE1 for 3750 switches.
Best regards,
Andras
