3750 Stack version mismatch problem
newfabcom
Hi, I am running a 3750E-48PD switch with firmware 15.2.SE1 UniversalK9 firmware as a master and I want to stack to a 3750G-16TD currently running 12.2(35)SE5 IP-Base. When i try to stack them I get a "booting in mismatch mode" and then it hangs. I understand the versions should match, but there is no UNIVERSAL version for the 3750g-16TD Switch. What can I do to make the stack work?
Thanks for any help.
- See more at: https://supportforums.cisco.com/discussion/12546216/3750-stack-version-mismatch-problem#sthash.waEk33pq.dpuf
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In theory, IOS versions don't need to match, but the IOS stack version software, embedded within the IOS, does need to match (at least, I recall, the major stack version number).  Normally, the easiest way to accomplish this is to run the same IOS version on all stack members.
I don't know if Cisco documents what stack version is supported by different IOS versions.
The 3750E should have IOS versions that overlap with those offered by the 3750G, although you may need to upgrade the 3750G and/or downgrade the 3750E to get them both on the same version.
BTW, IOS feature sets don't have to match between stack members either, although it's "nice" when they do.
5 Replies 5
Joseph W. Doherty
Disclaimer
Posting
Hi, Thanks for that info. is there any way to check the IOS stack version before or after installation?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html#wp56323
Thanks, I downgraded? to version 12 on the 3750E switch now it works. I dont know what the difference is between 12 and 15.
12 and 15 are two different major software version hence it wont work if you are running one switch with 12 and other switch in 15.
But what joseph is refereing is if you are running sofware wit different 12 series software it works what I mean is Main version will be 12.X (and sub version can be 12.2(X), 12.2(XX)..etc..)
