Leap Second - Nexus 9396P
Ryan17
I'm just double checking that NTP will not cause a problem in regards to today's leap second.
I found this bug: https://tools.cisco.com/bugsearch/bug/CSCut78541
but it looks to only be related to PTP and not NTP.
Can anyone else confirm this please?
Thank you!
InayathUlla Sharieff
Ryan,
N9k is only vulnerable to PTP leap second issue.
The PTP issue is fixed in following codes:
7.0(3)I1(2)
so as Reza already answered it if you are not running the PTP then no need to worry.
Inayath
*********Please mark the thread as answered if this has answered your query so that other be benefited with the same*****
Reza Sharifi
That is correct. If you are not using PTP, than there is no issue.
Ryan,
7.0(3)I1(2)
Inayath
