3750 stacking
g.rodegari
Level 5
Level 5
Hi all,
I've to stack just two 3750.
Do I need one or two stacking cable?
Thank you,
& Best Regards,
G.
cpembleton
Level 8
Level 8
You can do either. However, you'll get full bandwidth and redundancy when using both.
Chad
Please rate if this helps!
I'll go with the suggested solution with two cable.
Thank you and Best Reagards,
Graz.
