3750 StackWise
ljvelazquez
Community Member
I need to integrate a SW3750 X to my Lan core I mean I have five Switches 3750 work with StackWise, but the new has IOS version 12.2(58)SE2
and the others have the version Version 12.2(35)SE5.
do you think if the new get the configuration automatically or I need to do something
Those switches are not compatible with that IOS, I believe you can put the IOS version 15.0(1)SE on the 3750G switches according to the following document, but that would end up causing downtime by bringing your core stack down. Is there a specific need to adding more ports to make a larger core?
You could open a Cisco TAC case to further verify if this is a correct IOS that would be compatible, and/or what they would recommend.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/product_bulletin_c25_682542.html
14 Replies 14
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
There are some auto-upgrade feature for 3750 stacks, but I usually find it easier to insure all devices have the same IOS version before I combine them.
As to configuration, if the new switch is "new", it will join the stack as a "blank slate", although you can pre-provision it too.  If the switch to be added isn't new, I believe there are rules for "merging" but I generally also insure the switch to be added configuration is erased.  Then I configure its port when it joins the stack (or again, have pre-provisioned its ports; on the existing stack's configuration.)
You can stack 3750 switches as necessary, even if they come up as V-mismatch, you still have access to that switches flash, then you copy the current switch running IOS to the newly added switch, reload the slot NOT the stack, and you should have a new operable switch in the stack without losing any connectivity.
I've done this on multiple occasions, there are those few cases that this doesn't work for some reason, but you can just TFTP the IOS you want from a running 3750 and then xmodem or TFTP it on the new switch before adding it to the stack.
Thanks, I gonna try it.
I will search the procedure to add the current IOS on the new Switch and test it.
I have done this before, usually I upgrade the incoming switch to the version the others are running, just to eliminate any potential problems, this is because, for instance if the IOS on the incoming switch is new the you might upgrade the other switches inadvertently, if that happens you will have an outage as these switches in a stack takes almost 30 minutes to upgrade and come back up.
The procedure for easy reference is linked below.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/64898-upgrade-3750-stack.html
Hi Guys.
I have a new problema I was trying to install the IOS version 12.2(58)SE2 on the new Switch using the procedure, after reboot the Switch could not open the file, it is sending a messages "the hardware doesn't support this software" or something like that.
I mean now I need at least recovery the IOS of the new Switch (3750x-12s-s) using Xmodem or rommon
somebody have the procedure to do that?
LJ,
you should be installing the same version that is running in your existing stack as you stated it is version 12.2(35)SE5, you will have issues if you introduce a newer IOS into your stack, you will end up upgrading the others and causing downtime.
If you did not remove the old image you should be able to boot to it using the
boot flash:"imagename" command, if that does not work then you will have to use xmodem to transfer the image which takes a while.
The instructions are linked below, look for the section referencing the 3750 series.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
The version 12.2(35)SE5  is not supported  from the new switch (3750x) I could do recovery the IOS  using Xmodem now I have the version c3750e-ipbasek9-mz.150-2.SE8.
I dont know if that version will can work with my current Stack.
did you erase the old image, show us the flash directory of the down switch.
No, I didn't. I have to erase it? below show you the flash directory and the output of the show version command.
Switch#dir flash:
Directory of flash:/
    2  -rwx    20438656   Jan 1 1970 00:18:46 +00:00  c3750e-ipbasek9-mz.150-2.S
E8.bin
    3  -rwx         976   Mar 1 1993 00:11:08 +00:00  vlan.dat
    4  -rwx        1602   Jan 2 2006 00:55:23 +00:00  config.text
    5  -rwx        3096   Jan 2 2006 00:55:23 +00:00  multiple-fs
    6  -rwx        1914   Jan 2 2006 00:55:23 +00:00  private-config.text
    7  drwx        4096   Mar 1 1993 00:30:15 +00:00  c3750e-universalk9-mz.122-
58.SE2
119144448 bytes total (74731520 bytes free)
Switch#
Switch#sh version
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 15.0(2)SE8, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 23:01 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTW
ARE (fc1)
Switch uptime is 3 minutes
System image file is "flash:/c3750e-ipbasek9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision K0) with 524288K bytes of m
emory.
Processor board ID FDO1918F0WU
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 78:BA:F9:81:74:80
Motherboard assembly number     : 73-13329-07
Motherboard serial number       : FDO19180M1B
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3750X-12S-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO19180CCS
System serial number            : FDO1918F0WU
Top Assembly Part Number        : 800-35090-06
Top Assembly Revision Number    : E0
Version ID                      : V05
CLEI Code Number                : CMMPL00DRA
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 18    WS-C3750X-12S      15.0(2)SE8            C3750E-IPBASEK9-M
Configuration register is 0xF
Switch#
that's a completely different IOS than what you stated the current stack has running. you installed a 15.0 version IOS instead of the 12.2 version IOS.
Try to TFTP the current IOS on the stack to your laptop/computer and then xmodem or tftp it to the new switch to be added.
EDIT*** Are your other 3750 switches also X series??? could be an incompatibility issue between the switches. You need to either have compatible switches or find a compatible IOS that can span across the different style switches.
No, the other switches are WS-C3750G-12S-S (this five switches are the LAN Core)
and I did that, I get the IOS from the current Stack via TFT, and then loaded to the new switch but the serie X does not support the version of the current Stack for that reason I had to recovery the Switch serie X using Xmodem.
So you think this two switches are not compatible?
below is the output of the show switch detail command from the Current Stack.
SW_CORE_INNOPHOS#sh switch detail
Switch/Stack Mac Address : 0023.ebcc.5300
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
 1       Member 0000.0000.0000     0      0       Provisioned
*2       Master 0023.ebcc.5300     5      0       Ready
 3       Member f025.7204.9380     1      0       Ready
 4       Member d057.4cd1.2f00     1      0       Ready
 5       Member 68bd.ab4e.8b80     1      0       Ready
 6       Member 1caa.07ea.9f80     1      0       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  2        Ok         Ok                4        3
  3        Ok        Down               2      None
  4        Ok         Ok                5        2
  5        Ok         Ok                6        4
  6       Down        Ok              None       5
SW_CORE_INNOPHOS#
Hi Guys
I could solution it, I opened a case with the TAC and the engineer send me the links to download the IOS version for each Switch 3750G (c3750-ipbasek9-mz.122-55.SE10) and 3750X(c3750e-ipbasek9-mz.122-55.SE10).
After the upgrade those switch could do the Stack.
Switch/Stack Mac Address : 0023.ebcc.5000
                                           H/W   Current
*1       Master 0023.ebcc.5000     10     0       Ready
 2       Member 78ba.f981.7480     1      1       Ready
 3       Member 0000.0000.0000     0      0       Provisioned
 4       Member 0000.0000.0000     0      0       Provisioned
 5       Member 0000.0000.0000     0      0       Provisioned
 6       Member 0000.0000.0000     0      0       Provisioned
  1        Ok         Ok                2        2
  2        Ok         Ok                1        1
The switch 2 is the Switch 3750X
Thanks for your advices.
Best regards.
this is something I picked up online
Here is a doc with caveat to all of this… and we have the 12S and so buying an X won't work.
* The 3750-X Fiber switches (WS-C3750X-12S and WS-C3750X-24S) don't stack with the old WS-C3750G-12S switches due to
HW and SW limitations on the WS-C3750G-12S.
© 2011 Cisco and/or its affiliates. All rights reserved. This document is Cisco Public Information.
I believe this is what you have got so you won't be able to stack them anyway!
