3750 Swicth - Routing
tomd54321
Hello All,
So, I'm not normally a network engineer :) But have found myself in this most gracious position!
I have this environment that I need to route IP across the switches. Basically, I have VM host server that has three network connections.
NIC0 = 192.168.70.0/24 VLAN 100
NIC1 and NIC2 = teamed onto 192.168.71.0/24 VLAN 120
Don't let the teaming confuse things... In troubleshooting I have removed all the teaming configuration and made things as simple as possible.
The problem is that while logged in to the switch I can ping interfaces on the server in both VLANs. But I cannot ping from one endpoint to the other.
I have the VLANs defined, the vlan interfaces have ip addresses and I have 'ip routing' in the config.  Is this all that is required? Or am I missing something?
Cheers
Tom
Maybe the endpoints don't have default gateways configured? :)
6 Replies 6
Reza Sharifi
By default the 3750 is a layer-2 switch.  Now that you want to route between vlans (layer-3) you need to add this command to the switch:
config t
ip routing
exit
wr
and now test again between the end points.
Hello Reza,
"I have the VLANs defined, the vlan interfaces have ip addresses and I have 'ip routing' in the config.  Is this all that is required?"
This is not working. Any suggestions?
Tom
Hi Tom,
Can you post "sh run" and "sh vlan" and point out what interfaces connect to these servers?
And a "show version" would be nice too.
Thank you all for everything.
Late last night, I had this flash of inspiration to check the gateway on the device that isn't working and lo and behold, it was configured incorrectly. This makes ivaideanu answer closest to the resolution.
Cheers
Tom
