3750 switch interface crc/error problem
andrewswanson
Level 11
Level 11
Hello
I'm having a problem with a WS-C3750G-12S-E. I'm seeing CRCs/input errors only on specific interfaces on the 3750. Initially i thought this was a fibre issue so i cleaned/replaced the fibre patch leads as well as the SFPs at both ends. the CRC's/errors continued until i removed the SFP from the switch and placed it into another port on the same switch.
if i use interfaces gi1/0/1, 2, 5, 6, 9 or 10 i get errors/CRCs - if i move the SFP (fibre or copper) to interfaces gi1/0/3, 4, 7, 8, 11, or 12 the errors/CRCs stop. The output of "sh platform pm if-numbers" below shows that the switch has 3 asics (with 4 ports) - the interfaces i'm having a problem with are spread across all 3 asics but only on the last 2 ports (2 and 3).
interface gid gpn lpn port slot unit slun port-type lpn-idb gpn-idb
Gi1/0/1 1 1 1 2/2 1 1 1 local Yes Yes
Gi1/0/2 2 2 2 2/3 1 2 2 local Yes Yes
Gi1/0/3 3 3 3 2/0 1 3 3 local Yes Yes
Gi1/0/4 4 4 4 2/1 1 4 4 local Yes Yes
Gi1/0/5 5 5 5 0/2 1 5 5 local Yes Yes
Gi1/0/6 6 6 6 0/3 1 6 6 local Yes Yes
Gi1/0/7 7 7 7 0/0 1 7 7 local Yes Yes
Gi1/0/8 8 8 8 0/1 1 8 8 local Yes Yes
Gi1/0/9 9 9 9 1/2 1 9 9 local Yes Yes
Gi1/0/10 10 10 10 1/3 1 10 10 local Yes Yes
Gi1/0/11 11 11 11 1/0 1 11 11 local Yes Yes
Gi1/0/12 12 12 12 1/1 1 12 12 local Yes Yes
there is very little traffic through the switch and cpu is ok. Could this be a hardware fault? switch is currently running c3750-ipservicesk9-mz.122-55.SE6.bin ( upgraded from 52). output of the command sh platform port-asic stats drop for the affected interfaces show zero drops.
thanks in advance
andy
6 Replies 6
Alessio Andreoli
Level 11
Level 11
Try this :
http://packetlife.net/blog/2008/mar/28/investigating-ciscos-built-in-tdr/
and anyway i would check how duplex and speed are configured. they should be hardcoded and with no negotiation.
Alessio
thanks for the resonse Alessio - unfortunately tdr isn't support on sfp ports ( i get % TDR test is not supported on interface ) when i try. I've already double checked speed/duplex settings and all are ok. as i say, the problem is resolved when i move the sfp onto gi1/0/3,4,7,8,11,12 but i don't have enough of these 'working' ports for all my links.
thanks
andy
Hi Andrew,
Can you  please post the following output:
1.  sh version;
2.  sh controller e Gi ; and
3.  sh interface Gi
Hi Alessio,
Cisco switches will support copper TDR but OTDR is not yet supported.
hi leolaohoo - requested output below (for gi1/0/1 - one of the affected ports).
thanks
andy
sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE6,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 13:22 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
Mer3750SOC-C31-1 uptime is 1 day, 3 hours, 9 minutes
System restarted at 06:01:27 BST Mon Aug 13 2012
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C3750G-12S (PowerPC405) processor (revision H0) with 131072K bytes of m
emory.
Processor board ID CAT0828R0R2
Last reset from power-on
7 Virtual Ethernet interfaces
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:11:93:25:3C:00
Motherboard assembly number     : 73-8307-08
Power supply part number        : 341-0048-01
Motherboard serial number       : CAT08270HUH
Power supply serial number      : DTH082011GM
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : WS-C3750G-12S-E
System serial number            : CAT0828R0R2
Top Assembly Part Number        : 800-23419-01
Top Assembly Revision Number    : K0
Version ID                      : N/A
Hardware Board Revision Number  : 0x07
Switch Ports Model              SW Version            SW Image
*    1 12    WS-C3750G-12S      12.2(55)SE6           C3750-IPSERVICESK9-M
Configuration register is 0xF
sh controllers ethernet-controller gi1/0/1
     Transmit GigabitEthernet1/0/1            Receive
    259938503 Bytes                       1207273348 Bytes
       736997 Unicast frames                 1034568 Unicast frames
       320591 Multicast frames                214721 Multicast frames
       198162 Broadcast frames                 20997 Broadcast frames
            0 Too old frames              1184134313 Unicast bytes
            0 Deferred frames               16087093 Multicast bytes
            0 MTU exceeded frames            1724812 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames               52012 Minimum size frames
            0 8 collision frames              371239 65 to 127 byte frames
            0 9 collision frames               43419 128 to 255 byte frames
            0 10 collision frames              34665 256 to 511 byte frames
            0 11 collision frames              14625 512 to 1023 byte frames
            0 12 collision frames              32619 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions               730 Symbol error frames
            0 Late collisions                    119 Invalid frames, too large
            0 VLAN discard frames             722288 Valid frames, too large
            0 Excess defer frames                 31 Invalid frames, too small
         4033 64 byte frames                       0 Valid frames, too small
       943917 127 byte frames
       129003 255 byte frames                      0 Too old frames
        56374 511 byte frames                      1 Valid oversize frames
        40047 1023 byte frames                     0 System FCS error frames
        79734 1518 byte frames                     0 RxPortFifoFull drop frame
         2642 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
sh interfaces gi1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0011.9325.3c01 (bia 0011.9325.3c01)
  Description:
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4000 bits/sec, 2 packets/sec
  5 minute output rate 7000 bits/sec, 6 packets/sec
     1270755 packets input, 1207360054 bytes, 0 no buffer
     Received 235952 broadcasts (214916 multicasts)
     0 runts, 1 giants, 0 throttles
     730 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 214916 multicast, 0 pause input
     1256434 packets output, 260085515 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Thanks for the output.  Really helps.
Your line errors are "Symbol errors" being received by the interface.
May I ask what is connected to this?
This description is very "disturbing".  I believe the 3750 has a single 3 ASICs.  And if you say that moving the SFP to 3 & 4, ports 7 & 8 and ports 11 & 12 and the line errors stops, I am inclined to believe that the ASIC is failing.
