3750 switch POE not working on all ports
Natalie Ramirez
I have a 48 port 3750 POE switch, POE works fine on ports 6, 13, 16, 17, 19, 20, 30, 42, 44.  However, no other port will provide POE.  If I move a cable from port 6 and plug it into port 5, no errors on switch, no power to phone.  If I move it back to port 6, powers up exactly like it should.
Configuration on all 48 ports is exactly the same.  I have tried "power inline" "never", "auto", and "static", makes no difference.  I had to go port to port to find all the good POE ports, plug in, wait 10 seconds, move to next port.
Switch model number WS-C3750G-48PS-S
Running IOS version 12.2.25 SEB4
Is there a factory defect issue with POE on some 3750s?
8 Replies 8
Leo Laohoo
Post the complete output to the command "sh post" and "sh power inline".
switch#sh pow inl
Module   Available     Used     Remaining
          (Watts)     (Watts)    (Watts)
1           370.0       48.2       321.8
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Gi1/0/1   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/2   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/3   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/4   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/5   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/6   auto   on         6.4     IP Phone 8945       2     15.4
Gi1/0/7   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/8   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/9   auto   off        0.0     n/a                 n/a   15.4
Gi1/0/10  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/11  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/12  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/13  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/14  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/15  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/16  auto   on         6.4     IP Phone 8945       2     15.4
Gi1/0/17  auto   on         6.4     IP Phone 8945       2     15.4
Gi1/0/18  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/19  auto   on         13.0    IP Phone 8831       3     15.4
Gi1/0/20  auto   on         6.4     IP Phone 8945       2     15.4
Gi1/0/21  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/22  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/23  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/24  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/25  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/26  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/27  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/28  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/29  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/30  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/31  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/32  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/33  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/34  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/35  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/36  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/37  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/38  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/39  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/40  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/41  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/42  auto   on         3.3     IP Phone 7821       1     15.4
Gi1/0/43  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/44  auto   on         6.4     IP Phone 8945       2     15.4
Gi1/0/45  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/46  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/47  auto   off        0.0     n/a                 n/a   15.4
Gi1/0/48  auto   off        0.0     n/a                 n/a   15.4
switch# sh post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Hi there ,
Hope you had already rebooted the switch . if not , i would try that first .
i guess, POE is working fine on 1/0/6 . Have you try moving the same cable and phone to gi1/0/6 . If not working then you can try below things. But redirect the logging to buffer instead of console as its debug command .
sh power inline gi1/0/5
Debug condition interface gi1/0/5
debug ilpower cdp
debug ilpower controller
debug ilpower events
debug ilpower port
once you done above capture then do the same on working port Gi1/0/6 ., so you can identify the difference between working and non-working ports.
VS.Suresh.
*Plz rate the usefull posts *
Thanks for the output.
I wouldn't bother troubleshooting this issue any further until the IOS gets upgraded.  I mean 12.2(25)SEB-train is like, really old.
please power cycle the switch , and then try again, then post the "show power inline" command if still not working, also the "show log" command.
switch# sh logg
Syslog logging: enabled (0 messages dropped, 1 messages rate-limited, 0 flushes, 0 overruns, xml disab
led, filtering disabled)
    Console logging: level debugging, 2053 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 155 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty1(0)
    Buffer logging: level debugging, 2053 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Trap logging: level notifications, 2009 message lines logged
        Logging to 192.168.48.132, 2009 message lines logged, xml disabled,
               filtering disabled
Log Buffer (4096 bytes):
itEthernet1/0/13, changed state to up
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13, changed state to down
1w1d: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/13: PD removed
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13, changed state to down
1w1d: %ILPOWER-7-DETECT: Interface Gi1/0/13: Power Device detected: IEEE PD
1w1d: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/13: Power granted
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13, changed state to up
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13, changed state to up
1w1d: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/30: PD removed
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/30, changed state to down
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/30, changed state to down
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/23, changed state to down
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/23, changed state to down
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/23, changed state to up
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/23, changed state to up
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/19, changed state to down
1w1d: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/19: PD removed
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/19, changed state to down
1w1d: %ILPOWER-7-DETECT: Interface Gi1/0/19: Power Device detected: IEEE PD
1w1d: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/19: Power granted
1w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/19, changed state to up
1w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/19, changed state to up
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13, changed state to down
1w2d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13, changed state to down
1w2d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/13, changed state to up
1w2d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/13, changed state to up
Natalie,
do non POE devices work on the bad POE ports, I wonder if you have damaged pins on the switch
I see from the log you have not power cycled the switch can you try that, i take it you get nothing in the logs when you plug the phones into the bad ports
regards
Richard
Jason Dance
Could you please post the results from the following commands?:
Sh run int gi1/0/4
Sh run int gi1/0/5
Sh run int gi1/0/6
Sh run int gi1/0/13
Also, what make/model/firmware rev phone are you connecting to the switch?
How many of your 3750s are having the issue?
Have you tried a different IOS rev?
What is the exact model no of the not working 3750?
