3750 Switch stack port flapping
JaganV
Level 3
Level 3
Hi guys,
Need some advice.
I keep getting link flaps on my stack. Not sure where is the issue.
Powered down and checked all cables and connectivity but issue still there.
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2          Down          Ok
    3           Ok          Down
    4           Ok           Ok
    5           Ok           Ok
Here is the stack-port summary captured within few minutes.
Switch#/  Stack   Neighbor   Cable    Link   Link   Sync      #         In
Port#     Port              Length    OK   Active   OK    Changes   Loopback
          Status                                          To LinkOK
  1/1     OK         2      50 cm     Yes    Yes    Yes        1        No
  1/2     OK         5      1 m       Yes    Yes    Yes        3        No
  2/1     Down      None    50 cm     Yes    No     Yes     2367        No
  2/2     OK         1      50 cm     Yes    Yes    Yes        1        No
  3/1     OK         4      50 cm     Yes    Yes    Yes        1        No
  3/2     Down      None    50 cm     Yes    No     Yes        0        No
  4/1     OK         5      50 cm     Yes    Yes    Yes        2        No
  4/2     OK         3      50 cm     Yes    Yes    Yes        1        No
  5/1     OK         1      1 m       Yes    Yes    Yes        1        No
  5/2     OK         4      50 cm     Yes    Yes    Yes        1        No
          Status                                          To LinkOK
  5/1     OK        None    1 m       Yes    Yes    Yes        1        No
  5/2     OK        None    50 cm     Yes    Yes    Yes        1        No
          Status                                          To LinkOK
  1/1     OK        None    50 cm     Yes    Yes    Yes        1        No
  1/2     OK        None    1 m       Yes    Yes    Yes        3        No
  4/2     OK        None    50 cm     Yes    Yes    Yes        1        No
          Status                                          To LinkOK
9 Replies 9
Leo Laohoo
Can you post the output to the command "PID: WS-C3750"?
Command not accepted. You mean the sh inventory?
NAME: "1", DESCR: "WS-C3750-48P"
PID: WS-C3750-48PS-S   , VID: V06  , SN: xxxxxxx
NAME: "GigabitEthernet1/0/1", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN: xxxxxxxx
NAME: "2", DESCR: "WS-C3750-48P"
NAME: "3", DESCR: "WS-C3750-48P"
PID: WS-C3750-48PS-S   , VID: N/A  , SN: xxxxxxx
NAME: "4", DESCR: "WS-C3750-48P"
NAME: "5", DESCR: "WS-C3750V2-48PS"
PID: WS-C3750V2-48PS-S , VID: V06  , SN: xxxxx
NAME: "GigabitEthernet5/0/1", DESCR: "1000BaseSX SFP"
You may have a bad stacking cable or a bad interface on one of the switches.
Have a look at this doc for troubleshooting tips:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html#wp58952
Very nice.
How the heck am I suppose to help you if you block out the serial number????    The information I seek, whether or not your switch is part of the Field Notice, can be found in the first seven characters.
If you want to block them out, block out the last four characters.
JaganV
Level 3
Level 3
Some more info:
Switch#/   Lost Sync   # times Link   # Changes
  Port#      Events        Not OK      To LinkOK
  1/1               0             0           1
  1/2               0             2           3
  2/1               0          2367        2367
  2/2               0             0           1
  3/1               0             0           1
  3/2               0             0           0
  4/1               0             1           2
  4/2               0             0           1
  5/1               0             0           1
  5/2               0             0           1
Switch# sh switch stack-ring speed
Stack Ring Speed        : 16G
Stack Ring Configuration: Half
Stack Ring Protocol     : StackWise
Leo Laohoo
Field Notice attached.
Thanks Leo. I checked the document and my devices do not fall in those groups.
Jagan,
Kindly try changing the Cables now .
Whats the firmware its running?
Inayath
Thanks Inayath,
Tried changing the cable but still the same. In the end got the switch replaced and the stack is stable now.
