09-27-2012 12:27 PM - edited 03-07-2019 09:09 AM
Cisco 4506-E port configuration
WESTERN-4506-01#show int g4/47
GigabitEthernet4/47 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 0022.554c.01fe (
fe)
Description: Trunk to 425
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is 10/1
input flow-control is off, output flow-control is off
Last input 01:43:22, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output
Queueing strategy: fifo
Output queue: 0/40 (size/max)
38656 packets input, 3010717 bytes, 0 no buffer
Received 38090 broadcasts (36800 multicasts)
15006 packets output, 1389394 bytes, 0 underruns
0 lost carrier, 0 no carrier
interface FastEthernet1/0/3
description 425D1
switchport trunk native vlan 30
switchport trunk allowed vlan 30,35
switchport mode trunk
switchport nonegotiate
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
storm-control broadcast level pps 300
storm-control multicast level pps 300
storm-control action trap
macro description cisco-desktop
mac access-group AuthorizedHosts in
spanning-tree portfast
spanning-tree bpduguard enable
fe)
Cisco 3750 Configuration
interface FastEthernet1/0/1
description 425Link
I have mac address' populated. I can see the device in layout on CNA with the proper name however cannot ping it.
4506 is 10.30.30.1
3750 is 10.30.30.2
I need help, i know this is lower end stuff but for me . ..
thanks
Solved! Go to Solution.
09-27-2012 02:41 PM
From both switches can you provide "sh ip int bri fa1/0/1" and g4/47?
Is this
int g4/47
a 10/100/1000 interface?
09-27-2012 12:57 PM
The interfaces are are down. That means you have cable or optic problems. check the physical ports first.
09-27-2012 01:21 PM
the config i posted is the one i am using, the ports are up. i copied that from my file. i can see the ip address in the gui topology layout however cannot add it to the community.
09-27-2012 01:27 PM
FastEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0021.d751.3203 (bia 0021.d751.3203)
Description: 425Trunk
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
FastEthernet1/0/1 is down, line protocol is down (notconnect)
09-27-2012 01:31 PM
when you see below output, it means you have a layer-1 issue. This could be cabling, optic, patch panel ,etc.. If you walk to the switch and look at port 4/47 you don't see link light. Can you verify that?
09-27-2012 01:44 PM
3750 port 1 is blinking
4506 port 47 is solid. in fact all lights on 4506 are solid and rest of network is working properly.
09-27-2012 01:45 PM
these are actually up, i copied.
09-27-2012 02:41 PM
Is this
int g4/47
09-27-2012 02:55 PM
4/47
gigabitethernet4/47 unassigned ip address ok=yes method=unset status=up protocol=up
fa1/0/1 no access list no access list
on the wizard i used 10.30.30.2 255.255.255.0
09-28-2012 04:42 AM
Jeff
Can ypu post what Reza asked for ie. "sh ip int br" for both interfaces.
In addition - when you say you cannot ping it what are you trying to ping ie. from where (what IP and what device) to where (what IP and what device).
Jon
09-28-2012 08:53 AM
thanks guys vlan 1 was keeping it from connecting. i gave it a bogus address and now i am able to connect, now i will configure it.
