3750 upgrade code
6tgreene
Level 2
Level 2
I have a 3750, with 12.2(40)se on it. When I try and upgrade I get an out of space message. I'm unable to delete the bin file that is on the switch.
5 Replies 5
Tshi M
Level 9
Level 9
could you please post the exact message and also the command used to delete the bin file?
regards,
glen.grant
Is it a .bin file or is it a directory with the .bin file inside ? If you do a "dir flash" how many images are in flash?
Now that you point that out it is a dir. I changed to the dir and was able to delete the old file. I just completed the the new code upgrade. Thanks for the thought problem solved.
To delete the directory , "delete /force /recursive flash:
lagrn
Community Member
Are you using the archive command for the upgrade? Or are you doing it manually?
