3750 Voice Traffic
PAUL CHEN
I am trying to policed voice traffic on a 3750 and remarked it from CS3 to dscp 8
interface FastEthernet 0
switchport access vlan 10
switchport mode access
switchport voice vlan 20
(Are these commands correct ?)
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast
service-policy input mark-sccp
policy-map mark-sccp
class mark-sccp
set dscp cs3
police 9000 8000 exceed-action policed-dscp-transmit
class-map match-all mark-sccp
match access-group 101
access-list 101 permit tcp any any eq 2000
mls qos map policed-dscp 24 to 8
(Do I need this ?)
mls qos map cos-dscp 0 8 16 24 32 46 48 56
How do you see that the marking has changed if it exceeds 9000 in the scenario?
No matter how much traffic I put , i don't seem to see any change in the statistics.
Any help appreciated.
Thank you.
lgijssel
Level 9
Level 9
If remeber well, you cannot place this policy on a physical (layer2) interface with a standard image switch. It must be placed on a layer3 interface instead.
In this case, you should configure it on the voice vlan (20)
regards,
Leo
James Hawkins
Level 8
Level 8
Hi pjchen,
Are you trying to police voice payload traffic or voice signalling traffic.
Your config polices the signalling traffic which is pretty low bandwidth anyway.
To police voice payload traffic you need to change your class map statement to the following:
class-map match-all mark-voicertp
match ip rtp 16384 16383
Hi James,
Thanks for the reply. I am trying to police voice traffic, my mistake.
Are the rest of the configs correct then ?
Paul
Hi Paul
The config below should do what you are trying to achieve.
CAT3750(config)#mls qos map policed-dscp 0 24 46 to 8
! Excess traffic marked 0 or CS3 or EF will be remarked to CS1
CAT3750(config)#
CAT3750(config)#class-map match-all IPPHONE-VOICE
CAT3750(config-cmap)# match access-group name IPPHONE-VOICE
CAT3750(config-cmap)#class-map match-all IPPHONE-SIGNALING
CAT3750(config-cmap)# match access-group name IPPHONE-SIGNALING
CAT3750(config-cmap)#exit
CAT3750(config)#
CAT3750(config)#policy-map IPPHONE-PC
CAT3750(config-pmap)#class IPPHONE-VOICE
CAT3750(config-pmap-c)# set ip dscp 46 ! IPphone VoIP is marked to DSCP EF
CAT3750(config-pmap-c)# police 128000 8000 exceed-action policed-dscp-transmit
! Out-of-profile IPPhone voice traffic is marked down to Scavenger (CS1)
CAT3750(config-pmap-c)#class IPPHONE-SIGNALING
CAT3750(config-pmap-c)# set ip dscp 24 ! Signaling is marked to DSCP CS3
CAT3750(config-pmap-c)# police 32000 8000 exceed-action policed-dscp-transmit
! Out-of-profile Signaling traffic is marked down to Scavenger (CS1)
CAT3750(config-pmap-c)#class class-default
CAT3750(config-pmap-c)# set ip dscp 0
CAT3750(config-pmap-c)# police 5000000 8000 exceed-action policed-dscp-transmit
! Out-of-profile data traffic is marked down to Scavenger (CS1)
CAT3750(config-pmap-c)# exit
CAT3750(config-pmap)#exit
CAT3750(config)#
CAT3750(config)#interface GigabitEthernet0/1
CAT3750(config-if)# service-policy input IPPHONE-PC ! Applies policy to int
CAT3750(config-if)#exit
CAT3750(config)#
CAT3750(config)#ip access list extended IPPHONE-VOICE
CAT3750(config-ext-nacl)# permit udp any any range 16384 32767 ! VoIP ports
CAT3750(config-ext-nacl)#ip access list extended IPPHONE-SIGNALING
CAT3750(config-ext-nacl)# permit tcp any any range 2000 2002 ! SCCP ports
CAT3750(config-ext-nacl)#end
This is based upon the Enterprise QoS Design Guide at the link below:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoSDesign.html
