09-10-2015 06:23 AM - edited 03-08-2019 01:43 AM
I am trying to find the correct IOS for 3750 x switch. I tried 15.0(2) se8 tried ipbase and universal and neither support bgp
| E8 |
Solved! Go to Solution.
09-10-2015 08:15 AM
You have a IPbase licence level. BGP will not work
09-10-2015 06:51 AM
You will need Ip services to run BGP
"The LAN Base feature set includes comprehensive Layer 2 features, with up-to 255 VLANs. The IP Base feature set provides baseline enterprise services in addition to all LAN Base features, with 1K VLANs. IP Base also includes the support for routed access, StackPower (available only on the Catalyst 3750-X), MACsec, and the new Cisco Service Module. The IP Services feature set provides full enterprise services that includes advanced Layer 3 features such as Enhanced Interior Gateway Routing Protocol (EIGRP), Open Shortest Path First (OSPF), Border Gateway Protocol (BGP), Protocol Independent Multicast (PIM), and IPv6 routing such as OSPFv3 and EIGRPv6. All software feature sets support advanced security, QoS, and management features"
09-10-2015 07:44 AM
thank you however I downloaded c3750e-universalk9-mz.150-2.SE8.bin this image
I get this error
NOTE eigrp and ospf both work
SWITCH(config)#router bgp 1
Protocol not in this image
Why is set to this
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
09-10-2015 08:15 AM
