3750-X VRF aware WCCP 2.0
Roger Base
Hi. Does anybody know if VRF aware WCCP 2.0 are supported on 3750-X platform with code 15.0(2)SE1 (IPSERvices)? If not can this be fixed via IOS upgrade?
I found some WCCP VRF commands. But the switch dosent accept them . (ip wccp vrf blue web-cache.. etc)
The switch does not allow me to apply WCCP commands on the interface where I also have VRF forwarding on.
Switch1(config-if)#ip wccp 90 redirect in
% Error: VRF configuration on this interface prevents use of WCCP
Mark Malone
whats your license level you need ip services at least ?
WCCP is only supported on the Catalyst 3560/3750 running IP Services or Advanced IP Services feature sets, on IOS 12.2(25) and later.
3750-X platform with code 15.0(2)SE1 IP Services.
sorry I re-read your post after fully , didn't realise it was just not working due to vrf , there is restriction in all versions of ios with wccp when vrf is enabled reading the release docs
The switch does not allow me to apply WCCP commands on the interface where I also have VRF forwarding on.------That's correct its the same in v12 right through to latest v15 its a feature restriction unfortunately no way around from what I can see in the docs apart form using an interface that's not vrf enabled , they mention it in multiple versions do not try apply when vrf is enabled
from the doc
You cannot configure WCCP and VPN routing/forwarding (VRF) on the same switch interface.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_37_se/configuration/guide/3750escg/swwccp.pdf
You cannot configure WCCP and PBR on the same switch interface.
You cannot configure WCCP and a private VLAN (PVLAN) on the same switch interface.
