3750E TD-S or TD-E for eigrp routing
benny
Hi, I need to run EIGRP. In the beginning, we will just do EIGRP stub routing, so 3750E TD-S is good for us, but later we may reuse the same switch to do full EIGRP routing. My question is if we buy a 3750E-TD-S now, can we upgrade it to 3750E-TD-E for the full EIGRP routing function? Will a software IOS upgrade do that?
Thanks.
Ben
9 Replies 9
Joseph W. Doherty
Believe the answer is yes.
Thanks.
But I have colleagues tried that before, but didn't work. They said it seems to be hardware dependent.. even if they downloaded the IOS for 3750E-TD-E switch, when doing 'show version', it still showed as 'IP-Based' and only eigrp-stub routing is avilable, so I would like to confirm if that is the case, that a 3750E-TD-S cannot be upgraded to a 3750E-TD-E just by a IOS upgrade. I want to confirm that before we make the purchase. Thanks.
Jerry Ye
Hi Ben,
You can upgrade to the Enhanced image, since the 3750E-TD-S is the standard image. You will have to purchase the Enhanced image PAK from your reseller since the 3750E will require a license file.
HTH,
jerry
Hi Jerry,
So even if we can download the Enhanced image, we still need to buy a license in order to activate the full eigrp routing function?
Thanks!
Ben
Hi Ben,
That is correct, the new 3750E image is called the Universal image, and software features are activated by license key.
Here is the license example
Switch#sh license all
License Store: Primary License Storage
StoreIndex: 1 Feature: advipservices Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Priority: Medium
HTH,
jerry
Jerry,
Thanks a lot for your quick response!
StoreIndex: 0 Feature: ipbase Version: 1.0
License State: Active, In Use
License Count: Non-Counted
License Store: Evaluation License Storage
StoreIndex: 0 Feature: ipservices Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License Priority: None
This is a capture from my colleague's 3750E, it shows that there is an evaluation 'ipservice' license for 8 weeks. Does it mean we can somehow enable the 'ipservice license' for 8 weeks for testing?
If yes, how do we enable that?
Thanks!
Ben
Hi Ben,
I believe you can use the command license boot
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_46_se/command/reference/cli1.html#wp8991321
I cannot verify it in my lab switch.
Here is a link of the license activation commands and procedures
http://www.cisco.com/en/US/docs/ios/csa/configuration/guide/csa_commands.html#wpxref81295
HTH,
jerry
Thanks very much Jerry for your help!
Ben
You are welcome Ben.
