3750G Switch with PBR with IP SLA - Not working !!!
I am having a switch 3750G (WS-C3750G-24TS-S) running a software version (c3750-ipservicesk9-mz.122-55.SE6.bin) and using the PBR with IP SLA.
While, i am applying it on interface, it says not supported....
route-map TO-CAS-E0 permit 10
match ip address 125
set ip next-hop verify-availability 10.116.199.200 10 track 100     (if i change this command to set ip next-hop 10.116.199.200, it works)
WAN-L3-3750SW01(config-route-map)#interface GigabitEthernet1/0/11
WAN-L3-3750SW01(config-if)#ip policy route-map TO-CAS-E0
22:49:06: %PLATFORM_PBR-3-UNSUPPORTED_RMAP: Route-map TO-CAS-E0 not supported for Policy-Based Routing
Relevant configuration is attached...
Kindly, let me know that any alternative solution to use the PBR with IP SLA....
Mubasher Sultan
Hello Mubashir,
37xx doesnt support this option.. However the below thread gives you some information,  on what you are trying to achieve
https://supportforums.cisco.com/docs/DOC-8069
harish.
AhmedSonba
Hello mubashir
I have just tried your configuration on my university Cisco Lab just right now and it did not work as you said and googled your error  message and it turned out it is a hardware limitation
Which means that the route-map attached to an interface for policy routing contains an action that is not supported on this platform.
One work around is to make this action Routing this action
please the refer the follwoing link for more information
https://supportforums.cisco.com/docs/DOC-8313
It will make the same result " just an Idea"
Hope it will help
Ahmed Sonab
