3750x empty Flash
mannygawadcco
During initial boot up of the switch after joining to STACT i saw that the state is "Version Mismatch"
then after the reboot - i wasn't able to see the switch anymore. so i disconnected to stack connection and after that i reboot the switch and this is what i got from boot up process. see below logs --- Can anyone tell me what could be the issue, do i need to upload compatible IOS and connect it back to stack or anyone can confirm that this is a hardware issue.
Using driver version 3 for media type 2
Base ethernet MAC Address: f0:7f:06:56:b7:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 0 files, 1 directories
mifs[2]: Total bytes : 2097152
mifs[2]: Bytes used : 8192
mifs[2]: Bytes available : 2088960
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 4194304
mifs[3]: Bytes used : 8192
mifs[3]: Bytes available : 4186112
mifs[3]: mifs fsck took 1 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 524288
mifs[4]: Bytes used : 49152
mifs[4]: Bytes available : 475136
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 524288
mifs[5]: Bytes used : 49152
mifs[5]: Bytes available : 475136
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 498 files, 12 directories
mifs[6]: Total bytes : 119144448
mifs[6]: Bytes used : 8462336
mifs[6]: Bytes available : 110682112
mifs[6]: mifs fsck took 35 seconds.
...done Initializing Flash.
done.
Loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"...flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin: no such file or directory
Error loading "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/update/c3750e-universalk9-mz.122-55.SE8/c3750e-universalk9-mz.122-55.SE8.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Error loading "flash:/update/c3750e-universalk9-mz.122-55.SE8/c3750e-universalk9-mz.122-55.SE8.bin"
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch: dir
List of filesystems currently registered:
bs[0]: (read-only)
flash[6]: (read-write)
xmodem[7]: (read-only)
null[8]: (read-write)
tftp[9]: (read-only)
6 Replies 6
Leo Laohoo
The correct syntax is "dir flash:".
Leo Laohoo
Someone attempted to upgrade the switch but interrupted the upgrade.  So now the switch is attempting to boot a corrupt IOS.
Solution is to upgrade the IOS again.
this update is done by master in STACk
Can i join 3750x-12port in the existing stack with 2 3750x-24 ports?
Can anyone provide me with the steps in uploading the new IOS in this switch with "switch:" prompt?
Copy the BIN file into a USB thumb drive.
Instruct the switch to boot the file from the thumb drive using the command "boot usbflash0:IOS_filename.bin".
