09-27-2013 02:47 AM - edited 03-07-2019 03:42 PM
i have a problem with 3750X-POE, when the Power is to low i want to add a second Powersupply. Sometimes it doesn't get's recognized, I can see in the Log-file that power supply was inserted and power is good but a show inventory doesn't show the supply. Also the "show power inline" doesn't show the extra power.
Sometimes a reboot helps, sometimes we need to replace the switch.
I am using version: c3750e-universalk9-mz.122-58.SE1.bin
Does anybody know this problem?
09-28-2013 11:23 AM
Not sure, but you may check out bug CSCtn63506, looks like 12.2(58)SE1 is on the affected list.
Could you check the #show environment power and verify do you see the power supply?
Symptom:
When hot inserting power supplies and powering up in Incredibles, power supplies appear in 'show environment power' but do not appear in 'show inventory'.
Conditions:
The issue occurs on FRU PS for X-Series.
Workaround:
There is no workaround.
The issue does not affect an actual power supply
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtn63506
09-29-2013 11:54 PM
Hi Richard... thanks for this info, i will use a newer IOS and give it a try!
09-30-2013 11:56 PM
Hmmm:
"No release planned to fix this bug" I think i have to go to 15.x.x
09-30-2013 04:04 AM
Unrelated... but what does 'powering up in Incredibles' mean?
*imagining some Pixar animated characters*
