3750X stack auto vs. manual upgrade
lcaruso
Level 6
Level 6
Are there issues with the auto upgrade feature for 3750X stacks, either historically or currently?
Some people prefer to upgrade switch stacks manually by disconnectiong the stack cables and uprading code on each switch.
I've done the manual procedure in the past and have not tried the auto upgrade (I have the procedure for the auto upgrade).
What I'm asking is for anyone to share their experience either good or bad with the auto upgrade to assess if this technique is sound.
Thanks.
5 Accepted Solutions
Reza Sharifi
I upgraded 3 stacks of 3750X switches a couple of weeks ago using the .tar file with no issues at all. For a stack of 3 switches, it takes about 45 minutes, so you would need to be patient. Just load the .tar file on the flash of the master switch and run the archive command.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml#maintask1
Good Luck
Reza
Leo Laohoo
I've never heard of this kind of very manual form of IOS upgrade.
I've got about 90+ stacks of 3750/G/E/X in my network and it all boils down to the behaviour of the IOS I want to upgrade.
Let me explain:
I don't remember what IOS version it was but if you run the command "archive download-sw", the IOS won't like it:  CPU will spike and at the end, it will fail.
So I resort to the old method of "archive tar /x" on each stack member.
But if I was given a choice, "archive download-sw" is my preferred way of upgrading switches using the TAR file.
I have never used that command either, but here is step-by-step instructions: You load the file to flash1 for switch1, flash2 for switch2, flash3 for switch 3, etc....
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00804799d7.shtml#mupgrade
C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE1
Good G0d!  Please DO NOT use this.  Try 12.2(55)SE7 instead.
How do I perform archive tar /x on each member's flash. I've not used that procedure.
Take note that I only use this method as a "last resort".
Let's say you have three members in a stack.  So to upgrade the IOS on the first stack member, the command is:  archive tar /x tftp:///filename.tar flash1:
You wait for the entire download to complete and then you change "flash1:" to "flash2:" and so on.
The method "download-sw /destination X" is still superior, in my opinion.
NOTE:  I upgrade the IOS of my 3750 stacks about TWICE a year.  For my 2960S, I upgrade as often as I please.
The only way to use a .bin image which doesn't have the web manager is to break the stack, upgrade each switch as if it was standalone,
I disagree.  This method of upgrade is very extreme and totally un-necessary.
Ok, so you want to upgrade the BIN file?  It's very, very easy.  Say you have three switches in a stack, so the commands are:
1.  copy tftp:///filename.bin flash1:
2.  copy tftp:///filename.bin flash2:
3.  copy tftp:///filename.bin flash3:
No need to break the stack.  Once the BIN file is copied across all members of the stack, optionally you can verify the MD5 hash, and then you reboot.  Easy!
18 Replies 18
Reza Sharifi
Good Luck
Reza
Thanks for your reply. Hope I won't need any luck.
You should be just fine.  The USB port makes life really easy when you have a lots single switches to upgrade.  I have not idea why Cisco didn't add it long time ago while other vendors have been doing it
Reza Sharifi
Oh, BTW, the 3750X series switches come with a USB port.  So, no need for ftp, tftp, etc... Just load the IOS you want in to a flash drive and then insert it in to the USB slot. Copy from USB to flash and then run the archive command.
Cisco switches don't like every USB flash, once you insert it if the switch like it, it will let you know.
Leo Laohoo
Let me explain:
Excellent reply!
I'll be doing the upgrade on
Is that version anyway close to the version you had problems with?
Thanks much!
Sorry I meant I was upgrading from that version to the latest SE7.
Ok, that's COOL!
Now I know why some people prefer the manual method.
The .tar images only have the web based device manager, which we totally avoid for single devices.
The only way to use a .bin image which doesn't have the web manager is to break the stack, upgrade each switch as if it was standalone, then put it back together and use the priority commands to ensure each switch is in the correct order.
Thanks for your reply. I finally found time to read the entire link that Reza Sharifi provided which says the same thing you mentioned about the manual .bin upgrade. Worked like a charm.
Someone showed me the break the stack method 2 years ago for a 2960S stack, and I had mistakenly been led to believe that was the only way to get it done for the .bin image.
Thanks once again to all that took the time and effort to reply.
Try Rolling Stock Upgrade (aka Rolling Stones).  It's alot groovie!
Upgrade of the 2960S is far more simpler than the 3750 family.  The IOS is smart enough to determine how many switches in the stack and you dispense of the need to use the "/destination" option.
