What will a switch do when
mikegrous
Level 3
Level 3
There is an arp entry..But no port for the cooresponding MAC address?
#sho ip arp 10.200.0.14
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.200.0.14             4   001d.45e2.8d43  ARPA   Vlan200
Rack20-L3-3750-12#sho mac add dy | i 8d43
7 Replies 7
Reza Sharifi
is 10.200.0.14 connected directly to this switch?
yes. Over a directly connected VLAN
If a frame comes into the switch to be forwarded and the switch does not have an entry for the MAC in its mac-address table then the switch will flood the frame to every port in that vlan except for the port on which it arrived.
Rick
Rick
thats what i thought. So the dest MAC would be a broadcast MAC. The return traffic would then populate the MAC table.
Just to be clear - the destination mac is not a broadcast, but the forwarding activity is the same as if it were a broadcast. The technical name for it is unicast flooding. And yes, the response traffic source mac address should be used to build an entry in the mac-address table.
Rick
Rick
Got it thank you.
I am glad that we were able to help to clarify the expected behavior. If you are satisfied with the responses perhaps you can mark this question as answered?
Rick
Rick
