06-09-2014 11:35 PM - edited 03-07-2019 07:40 PM
Our client has a stack of four WS-C3750X-48PF-S switches running 122-58.SE2.
CPU normally sits at 40% with Hulc Led Process using 20%.
Whenever the client uses Symantec Ghost to multicast images to a few pc's, the CPU goes to 60-65%.(low interrupts)
Hulc Led Process increases from 20% to over 40% and we begin to see performance issues. (ip phones unregistering, voice quality issues)
The client has always used Ghost at other sites with switches other than the 3570X without issues.
IGMP snooping is applied to all switches which should limit flooding.
Logs just show constant QOS trust state flapping of many ports which I"m guessing is the phones resetting.
%SWITCH_QOS_TB-5-TRUST_DEVICE_LOST
%SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED
sh proc cpu sorted | e 0.00
CPU utilization for five seconds: 62%/1%; one minute: 63%; five minutes: 64%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
169 2217217478 1221756240 1814 41.11% 40.29% 39.63% 0 Hulc LED Process
84 1172730971 710491500 1650 4.79% 4.51% 4.38% 0 RedEarth I2C dri
85 2347135764 473185300 4960 3.83% 3.79% 3.85% 0 RedEarth Tx Mana
129 900160394 102656819 8768 1.75% 1.98% 2.01% 0 hpm counter proc
232 147346287 303244735 485 1.27% 0.87% 0.79% 0 Spanning Tree
12 81720858 110076589 742 0.63% 0.29% 0.28% 0 ARP Input
181 182012633 9973080 18250 0.47% 0.46% 0.47% 0 HQM Stack Proces
259 92723044 74624511 1242 0.31% 0.15% 0.14% 0 XDR mcast
214 74069998 286681859 258 0.31% 0.12% 0.12% 0 IP Input
182 186201884 78177514 2381 0.31% 0.48% 0.48% 0 HRPC qos request
130 81857170 311631399 262 0.15% 0.20% 0.19% 0 HRPC pm-counters
107 19751840 1217497713 16 0.15% 0.15% 0.12% 0 HLFM address lea
86 41554684 334517325 124 0.15% 0.14% 0.13% 0 RedEarth Rx Mana
371 14803318 1052044058 14 0.15% 0.09% 0.10% 0 PIM Process
288 43349962 4914171 8821 0.15% 0.09% 0.10% 0 QoS stats proces
292 14095075 107528293 131 0.15% 0.09% 0.09% 0 Marvell wk-a Pow
43 36398731 8754807 4157 0.15% 0.08% 0.09% 0 Net Background
320 11719806 1527234091 7 0.15% 0.05% 0.05% 0 MMON MENG
279 5230640 99514899 52 0.15% 0.05% 0.02% 0 DHCPD Receive
I have a TAC case open but any suggestions would be appreciated.
06-10-2014 06:09 PM
Downgrade to IOS version 12.2(55)SE9 for better stability.
"Hulc LED Process" is a process which detects if interfaces are active or down. 12.2(58)SE-series train is one of the few IOS versions/train which have CPU hog issues caused by this process. I would recommend IOS version 12.2(55)SE9 for 3560- and/or 3750-series family of switches.
06-11-2014 01:53 AM
Dear Friend,
As the process is related to syslog the link failures, what I can suspect is - there can be multiple failures at L1.
If you still sure, there are no physical link flaps, try shutting the ports one by one and see the changes in process...
Parvesh
