CISCO2921-SEC/K9 vs CISCO2921-HSEC/K9
jacob6000
I know the ISR2 series included VPN hardware acceleration but there is a "HSEC" which included an "advanced" encryption card. I'm just trying to get my head around it. Is the HSEC bundle really needed over the standard SEC bundle?
I need to support a 50meg Internet connection with 4 Site-to-Site VPNs and use of the firewall, nat and QOS on each router. I'm looking at the Cisco2921-SEC/K9 bundle. Does this sound about right?
Thank you,
5 Replies 5
jacob6000
Anybody used the HSEC bundle?
If your internet link is 50mb, then a 2921 (non-HSEC) can handle the encryption/decryption.
I don't know if I'd necessarily agree with that.  The standard SEC license comes with a software-based rate limiter of 85 Mbps each way.  If the protocol does not handle loss/retransmissions very well, throughput can easily plummet.  Testing in a lab environment with two 2921s, I saw speeds drop to 25 Mbps.
SOcchiogrosso
Level 4
Level 4
Info on the HSEC license can be found here in regards to what it is and what t does for you. It allows for addition through for encrypted traffic nasa higher number of VPN tunnels
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/qa_c67_606268.pdf
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
Parvesh Paliwal
Level 3
Level 3
As far as 50 mbps traffic is concerned, you can go with any of the options - HSEC is an improvement to the original SEC.
As it removes certain restrictions regarding VPN tunnels and bandwidth limits.
Parvesh
