03-12-2022 07:00 AM
I have 4 x 48 port switch stack of 3750x and have been tasked to split the task how would it be best to split it.
SW1 IS MASTER
I was thinking of moving sw3 and sw4 and make it its own stack but I have no spare ports as backup if I do it this way I will have 42 ports free on sw1 and sw2 and 42 ports UP ports to move from SW3 and SW4.
If I do Sw1 and Sw4 as one stack as Sw4 has more spare ports how do I renumber the stack and change from gi4/01 to gi2/0/1 whilst switch 2 is still in the stack.
What is the best way of doing it without having to reboot the whole stack?
03-12-2022 07:15 AM - edited 03-12-2022 07:15 AM
Easy way to Make 4 switch stack to 2 different stack.
1. Leave Switch 1 and 2 as it is, so there is no downtime required.
2. Move the Active connection from SW3 and Sw4 to consolidate to SW1 and SW2
3. Once that is Moved to SW1 and SW2.
4. Turn Off SW3 and SW4 ( remove the Stack cabled behind, Close Stack Ring SW1 and SW2
5. Take out SW3 and SW4, Build a New Stack. ( each switch renumber manually
SW3#switch 3 renumber 1
SW4#switch 4 renumber 2
save the config
6. Offline build the Stack SW3 and SW4 (now they will be SW1 and SW2)
7. configure you new stack as per the requirement link uplink port, VLAN config.
8. Save the config
9. Connect uplink to respected switch, Turn on new Stack and Test it.
Hope this steps make sense ?
03-13-2022 12:56 AM
03-13-2022 01:00 AM
Can you also do SW1 and SW4 as one stack and re number switch to sw2 or does switch 2 have to be shut down before this can he done and change the priority or does the whole stack need to be rebooted for changes to take effect?
03-13-2022 12:07 PM
If your SW1 and SW2 is fulll, then the conversation here ends, there is no point to split the switch to 2 different switches since you do not have future requirement.
without reload and service interruption you can remove SW3 and SW4 is the easy way.
If you turn off the Whole stack in the Maintenance window, you can what ever you like of the combination.
Make sure new Stack if you like to interact with the existing switch stack, either your uplink to core or dist switch.
Note: Suggest making a small network diagram of what you looking to do, so you get an idea also easy to implement rather than illustrating over words.
03-13-2022 10:10 AM - edited 03-13-2022 10:12 AM
Hello
No sure I understand what switches you wish to remove, but I would say at the end of the day you have the same amount of ports no mater what you remove.
If the stack at present has a full closed stack ring and sw1 is master with sw2 backup then it would be easier to remove sw3-4 so not to disrupt traffic for sw1/2 users or start renumbering switches
03-13-2022 10:54 AM
