3825 supported network module question
josephp
Hello folk, I have a 3825 and I wanted to add an NM-2FE-2W network module. I'm not sure if this is support by the router. Kindly let me know If this is possible.
2 Accepted Solutions
Collin Clark
In the datasheet for the 3800 series it shows the NM-2FE2W-V2 as a supported card.
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
Hope that helps.
ajagadee
Yes, its supported.
NM-2FE2W*
2-port 10/100 Ethernet 2-WIC-slot network module
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/prod_qas0900aecd8016a953.html
Arul
*Pls rate if it helps*
Collin Clark
Hope that helps.
Thanks for your help sorry it took me a while to rate/respond to your answer.
ajagadee
Yes, its supported.
NM-2FE2W*
Arul
Arul,
Thanks for your help on this, sorry it took me a while to respond.
