3845 Router do not work with NME-X23ES-1GP Interface card
oxyomillk
Need help!
I Trying install interface card NME-X 23ES-1GP on 3845 Router. I installed this card in slot 4, but router could not communicate with this card.
IOS version in Router 12.3
Here is results show diag command:
Slot 4:
Unknown (type 1187) Port adapter
Port adapter is disabled deactivated
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-25011-01
Board Revision : A0
Deviation Number : 0-0
Fab Version : 03
PCB Serial Number : FOC090009VC
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NME-X-23ES-1G-P
Version Identifier : V01
Base MAC Address : 0013.8088.9f80
MAC Address block size : 128
EEPROM format version 4
EEPROM contents (hex):
Possibly IOS release too old?
I checked the documentation again, it looks like you need at least IOS 12.3(14)T on the router, can you try and load this and check if that makes a difference ?
GP
from what I can tell from the documentation, the EtherSwitch module uses its own IOS, which must be compatible with the IOS on the router:
Prerequisites for the Cisco EtherSwitch Service Modules
The IOS version on the Cisco EtherSwitch service modules must be compatible with the Cisco IOS software release and feature set on the router.
- To view the router, Cisco IOS software release and feature set, enter the show version command in privileged EXEC mode.
- To view the Cisco EtherSwitch service module IOS version, enter the dir flash: command in privileged EXEC mode.
If the IOS used by the EtherSwitch module is not the same, use the procedure below to upgrade:
Upgrading the Cisco EtherSwitch Service Module Software
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_feature_guide09186a0080415bae.html#wp1773245
HTH,
GP
Thank you for link. I read all information on this link. But I can't solve the problem.
Commands "show version" and "show flash:" show my the IOS image file version on Router (but not on interface modules). Here is Routers IOS image:
c3845-advipservicesk9-mz.123-11.T5.bin
I Can't connect to and open a session on the interface module. Command service-module interface slot/port session don't work.
What I should do next?
May is ncessarily upgrade Software on router?
Here is results show version and show flash:
BIG1#show flash:
-#- --length-- -----date/time------ path
1 29801400 Jun 28 2005 04:47:46 +00:00 c3845-advipservicesk9-mz.123-11.T5.bin
2 1651 Jun 28 2005 04:55:18 +00:00 sdmconfig-38xx.cfg
3 3085312 Jun 28 2005 04:55:40 +00:00 sdm.tar
4 763392 Jun 28 2005 04:55:56 +00:00 es.tar
5 820224 Jun 28 2005 04:56:10 +00:00 common.tar
6 1038 Jun 28 2005 04:56:24 +00:00 home.shtml
7 113152 Jun 28 2005 04:56:36 +00:00 home.tar
8 749101 Jun 28 2005 04:56:52 +00:00 256MB.sdf
9 1208320 Jun 28 2005 04:57:08 +00:00 ips.tar
27451392 bytes available (36560896 bytes used)
BIG1#show version
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.3(11)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Sat 02-Apr-05 15:14 by yiyan
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
BIG1 uptime is 57 minutes
System returned to ROM by reload at 07:11:45 UTC Tue Jul 12 2005
System image file is "flash:c3845-advipservicesk9-mz.123-11.T5.bin"
Cisco 3845 (revision 1.0) with 223232K/38912K bytes of memory.
Processor board ID FCZ0927714C
2 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
GP
Thank you very match for yours help!
I upgraded Router software to version 12.3(14) and now all works fine.
