02-25-2009 02:02 PM - edited 03-06-2019 04:15 AM
I have a 3845 with a VWIC2-2MFT-T1/E1. My T1 was working but we hade to remove a wic card and a DSP to install it in another router.
Since we made that change our T1 does not come up. We erase the configuration that was in it and configure the router again from the start.
The service provider told me that the problem is not coming from them...
Here is my configuration in attachment
02-25-2009 02:12 PM
Did you do a loopback test?
02-25-2009 02:34 PM
Yes we did. I use a loopback in the wic card and I loop the ethernet patch cord.
02-25-2009 02:48 PM
Did you power off the router before you removed the WIC.
02-25-2009 02:54 PM
Yes sir
02-25-2009 02:55 PM
Is the provider providing clocking on those circuits? And are they 24 channels?
02-25-2009 05:12 PM
Yes the local telco provide the clock and they are 24 channels
05-29-2009 06:04 AM
I am having the same issue... was there any resolution...
05-29-2009 09:45 AM
My problem came from the T1.
