3850 & 10G Network Module
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading!
I've got a WS-C3850-24T with a  C3850-NM-4-10G inserted.  A show inventory reveals the switch doesn't see the 10G module.  I've swapped:
The failing module into 3850 #2 and it was recognized
A recognized module from 3850 #2 into 3850 #1 and the module was not recognized.
Have you seen this before?  Almost forgot: 3850 #1 is a 2-member stack.
Thanks!
Bob
adwang_bing
Level 3
Level 3
Is the switch you inserted the NM-4-10G into in 3850#2 a 48 port or 24 port switch?  The 24 port 3850 does not support the NM-4-10G and will only support the NM-2-10G and NM-4-1G.
Reza Sharifi
Hi Bob,
I have not seen that but I think you should reproduce it and call TAC.  They may need to replace the switch if there is something wrong with the slot on switch#1.  Since they are stacked I am assuming you have installed the same IOS in both switches right?
Hi Reza,
Thanks for writing.
Yes, the stack is running in INSTALL mode; same IOSs on both members.
I usually figure if the stuff doesn't work, then it's probably my process.
I'm opening a ticket with TAC.
Thanks again for writing,
Bob
adwang_bing
Level 3
Level 3
Philip D'Ath
Meraki Community All-Star
adwang_bing  is correct.  C3850-NM-4-10G is not supported in a WS-C3850-24T.   You'll need to use a C3850-NM-2-10G.
