Raw Ethernet on Cisco SF220-24 Smart Plus Switch
mehdi.mezouak1
Hello everybody !
I have a cisco SF220-24 ports 10/100 Smart Plus Switch and I want to use it to connect 3 mbeds card (Cortex-M4 ) or more, with just raw Ethernet no TCP/IP. Well I tried to send an ethernet packet directly from the fisrt mbed card to the second one which receive the packet and print the data id does work but when I try to do the same thing but using the switch actually it doesn't work and I think it's due to the configuration of the switch I'm not sure of that ! Do you have any suggestions? Can you please help me.
Thank you
0 Replies 0
