3850 copy ios from usb
as00001111
Hey guys,
I have a Fat32 formatted usb stick with a ios image for the 3850.
I do a copy usbflash0:cat.... flash:
it says:
0 bytes copied in 0secs.
After that, the image on the usb stick is also 0 bytes.
What can I do?
Thanks!
Mark Malone
so the the format is working if the 3850 can see its contents in flash
Can you post exactly what your doing the full outputs
if you copy say a text file as another test is the same thing happening to that as well ?
try another USB see if the issue is isolated to that por the switch itself too
other option copy it by ftp /tftp or scp and not use the USB if your in a rush to get it on
