3850 doesn't boot automatically, even after boot system switch all flash:packages.conf in the configuration.
Tuan Nguyen
After upgrading to the latest code.
The system is not configured to boot automatically.  The
following command will finish loading the operating system
software:
    boot
switch: boot
Even with boot system switch all flash:packages.conf in the configuration and save
boot-start-marker
boot-end-marker
All input are welcomed and appreciated.
tprivett
The reason that your switch is not booting automatically, even though you have the boot statement configured, is most likely your config-register.
Check the output of the 'show version' command, and at the very bottom you should see something like this:
Configuration register is 0x102
If your value is something other than 0x102 change it, from configuration mode, using the command 'config-register 0x102'
My config register is configured as 0x102 and I am still experiencing the same issue as the original post.  Any other ideas?
Thank you,
Joe
Hello.
When in bootloader ( switch:  ) you have to set MANUAL_BOOT=no
after that the switch boots automatically from the bootvar which is entered.
I am having the same issue, but only after a diagnostics test.  It boots correctly after a power failure, but not after i use the command line.  If i use the command line: switch#reload; it says the switch is not enabled for automatic booting.  However I checked the settings, which are:
config reg 0x102
boot variable=flash:packages.conf
manual boot=no
enable break=no
boot mode=device
ipxe timeout=0
Please advise.  Is this switch a failure and needed to be returned?
