3850 Lanbase : SMART_LIC-4-EVAL_WILL_EXPIRE_WARNING
chonman
I have Cisco WS-C3850-24T-L x2units (Stacking) running IOS XE Fuji 16.9.1
I using Layer2 feature only+ stacking ,but I got some warning about evaluation period will expire.
The event log as below:
Nov 14 11:54:36 UTC: %SMART_LIC-4-EVAL_WILL_EXPIRE_WARNING: Evaluation period will expire in 30 days.
Nov 23 11:54:22 UTC: %SMART_LIC-4-EVAL_WILL_EXPIRE_WARNING: Evaluation period will expire in 21 days.
So what happens if the evaluation expired?
After evaluation expired , Can I use the switch as usual?
Do I need to order additional license?
Thank you.
Chonman.
Leo Laohoo
If you reboot the switch, does the problem go away?  It could be CSCvh85225.
I'd recommend you raise a TAC Case.
Thank you , I will raise a TAC case .
I never test to reboot device, because device on production environment (running 24x7 without downtime).
Hello, did you ever get a solid answer to:
If so, can you share?
Hi salleek,
I open case to Cisco license team, They can fixed my problem.
They will assign your sale order to your Smart Account.
Cheers,
Chonman.
