12-22-2018 11:27 PM - edited 03-08-2019 04:52 PM
would like to do code upgrade one at a time in VSS 4500 switches . kindly suggest us if we are able to do that and also share the step by step procedure if possible. because cisco says that we need to completely reload VSS 4500 switch during IOS upgrade. if that is the case we need downtime but we need to maintain high availability. in VPC we are able to achieve what we are looking for but in VSS we are not sure how to do that
kindly share your thoughts
Solved! Go to Solution.
12-24-2018 10:43 PM
12-25-2018 03:22 AM
12-23-2018 12:41 AM
12-24-2018 09:04 PM
Hi Leo,
Thanks for your response. it seems you have given procedure for normal IOS code upgrade but I would expect procedure for the below .
as we know VSS switch is nothing but combination of two switches. while doing code upgrade how to upgrade one switch at a time in VSS without affecting traffic flow through this VSS. if this is possible we don't need to have downtime while doing code upgrade I believe. I would like to have step by step procedure for this.
12-24-2018 10:43 PM
12-25-2018 03:22 AM
