3850 NBAR
DJX995
Level 3
Level 3
I'm trying to update the NBAR protocol pack on my 3850.
However, the new protocol pack is not activating.
Cisco IOS XE Software, Version 16.08.01a
ip nbar protocol-pack flash:/pp-adv-cat3k-166.4-31-39.0.0.pack
NBAR software version:  33
NBAR minimum backward compatible version:  33
NBAR change ID:  229249
Loaded Protocol Pack(s):
Name:                            Advanced Protocol Pack
Version:                         36.0
Publisher:                       Cisco Systems Inc.
NBAR Engine Version:             33
State:                           Active
Version:                         39.0
NBAR Engine Version:             31
Creation time:                   Sun Sep 16 14:12:36 UTC 2018
File:                            flash:/pp-adv-cat3k-166.4-31-39.0.0.pack
State:                           Inactive
I also tried to load the pp-adv-cat3k-169.1-34-39.0.0.pack but I got the same result.
No error messages but the protocol pack never becomes active.
according to the matrix linked below you need Fuji (16.9) for pack 39...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_nbar/prot_lib/config_library/nbar-prot-pack-library.html
