3850 not keeping configuration after boot
mblake001
we just recieved our 3850 switches and i have one that will not reboot to the startup config. im pretty sure i can fix the problem in rommon mode but so far nothing works to get it into rommon mode. anyone have any ideas?
thanks
20 Replies 20
Mark Malone
whats your config register set to in show version ?
This is what it shows in the config register
"Configuration register is 0x142 (will be 0x102 at next reload)"
The 4 in 0x142 tells the device to ignore the startup config at boot time. This is why it has not seemed to retain the startup config. I suggest that you go ahead and reload. If the config register is then set to 0x102 then the startup config should work as expected.
Rick
Rick
we use the command
"config-register 0x102"
that did not work
The config-register command by itself does not fix it. After executing the command you must reload for the problem to be fixed.
Rick
Rick
i did
Commands:
config-register 0x104
exit
reload.
this did not fix it.
also tried :
config-register 0x0
exit
reload
to get into rommon, didnt work either
Have u tried below:
Conf t
end
wr
reload.
tried that, still didnt work
This is what worked
#config-register 0x102
#no system ignore startupconfig
Glad to know that you got it solved. Thank you for posting back to the forum to let us know how you fixed it. I have not seen that command before and it is interesting to know that it exists.
Rick
Rick
Thank you! I've been stuck in this state for more than an hour and this was helpful!
Fantastic. It worked for me! Thank you.
I had a same issue and this commands work, Model:3850, (IOS Version 16.3.6)
#no system ignore startupconfig switch all
or
#no system ignore startupconfig switch <1-9>
very useful resolution. Thanks for sharing in the community.
Not sure this is something to do where we want to reuse a stacked switch as a standalone switch - a first-time issue faced while making a switch as a standalone switch.
(config)#no switch 1 provision ws-xxxxx
(config)#end
#switch 2 renumber 1
#wr
#reload
After configuring the switch and reload - system back to Config-reg 0x142 and though I could see the config in the startup file in nvram. Then did the following and reloaded.
(config)#config-register 0x102
(config)#no system ignore startupconfig switch all
(config)# Hostname SW1
(config)#end
#wr
#reload
#reload
