3850 Stack IOS not staying on reboot
david.klein
I have followed these instructions:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html
When a reboot is done, only one switch stays with the correct updated IOS.
The other switch only comes up with "switch" prompt and I need to run command :
boot flash:packages.config , then the switch boots back up and is in stack.
While switch that will not boot correctly is sitting at "switch:" prompt, the other switch which booted correctly shows this when I issue command "show switch"
Switch#   Role    Mac Address     Priority Version  State
*1       Active   cc98.91e6.2c80     15     V06     Ready
 2       Member   0000.0000.0000     0      0       Provisioned
If I power off switches again, only one comes up properly, and same thing happens all over again.
Philip D'Ath
The default config register for a 3850 is 0x102.  Check that setting.
Anything interesting appear in the log when it fails to boot up?
I will need to console in and check what I see in the logs.
Thanks for the reply
