06-11-2018 02:17 AM - edited 03-08-2019 03:19 PM
Good Day,
I have one 3850, I copied the IOS via tftp server:
Switch#show flash:
-#- --length-- ---------date/time--------- path
2 2097152 Jun 11 2018 08:49:59.0000000000 +00:00 nvram_config
3 2097152 Jun 11 2018 08:49:59.0000000000 +00:00 nvram_config_bkup
4 19167872 Nov 03 2017 21:46:52.0000000000 +00:00 cat3k_caa-guestshell.16.06.01.SPA.pkg
5 27722412 Nov 03 2017 21:46:50.0000000000 +00:00 cat3k_caa-rpbase.16.06.01.SPA.pkg
6 331174520 Nov 03 2017 21:46:52.0000000000 +00:00 cat3k_caa-rpcore.16.06.01.SPA.pkg
7 14783104 Nov 03 2017 21:46:50.0000000000 +00:00 cat3k_caa-srdriver.16.06.01.SPA.pkg
8 16126588 Nov 03 2017 21:46:50.0000000000 +00:00 cat3k_caa-webui.16.06.01.SPA.pkg
9 4753 Nov 03 2017 21:47:10.0000000000 +00:00 packages.conf
10 4096 Nov 03 2017 21:48:56.0000000000 +00:00 .installer
11 259 Jun 11 2018 08:46:23.0000000000 +00:00 bootloader_evt_handle.log
12 4096 Nov 03 2017 21:55:15.0000000000 +00:00 core
13 4096 Nov 03 2017 21:49:35.0000000000 +00:00 core/modules
14 1 Jun 11 2018 09:04:54.0000000000 +00:00 core/.callhome
15 4096 Nov 03 2017 21:49:32.0000000000 +00:00 .prst_sync
16 4096 Nov 03 2017 21:49:36.0000000000 +00:00 .rollback_timer
17 4096 Jun 11 2018 08:46:40.0000000000 +00:00 dc_profile_dir
18 169431 Jun 11 2018 08:46:40.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
19 169431 May 16 2018 08:50:26.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
20 4096 Nov 03 2017 21:49:44.0000000000 +00:00 gs_script
21 91870 Jun 11 2018 08:47:01.0000000000 +00:00 memleak.tcl
22 1 Jun 11 2018 07:40:45.0000000000 +00:00 pnp-tech-time
23 111729 Apr 09 2018 07:53:05.0000000000 +00:00 pnp-tech-discovery-summary
24 537577577 Jun 11 2018 08:38:29.0000000000 +00:00 cat3k_caa-universalk9.16.03.06.SPA.bin
584802304 bytes available (954773504 bytes used)
"cat3k_caa-universalk9.16.03.06.SPA.bin" is the one which I copied, on doing reload it is not taking the new IOS..
Switch#show version | begin Switch Ports
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48T 16.6.1 CAT3K_CAA-UNIVERSALK9 INSTALL
Configuration register is 0x102
Switch#
16.6.1 is still the old one..any suggestion pls...
06-11-2018 02:49 AM
You need to install the software using the following command:
"request platform software package install switch all file flash:cat3k_caa-universalk9.16.03.06.SPA.bin new"
Have a look at the release notes at the following link:
John
06-11-2018 07:26 AM
Many Thanks for reply,
Just to inform I did the below process step by step.
1 - Assign IP to existing / create vlan to access TFTP server (any machine one the LAN)
conf t
inter vl 1
ip add 192.168.100.1 255.255.255.0
no sh
end
1 - Prepare any port for that VLAN
int gi 1/0/1
swi
swi mo access
swi access vl 1
exit
3 - ensure the connectivity (both ways)
ping 192.168.100.100 (IP for TFTP server)
4 - Assuming IOS is downloaded on server and TFTP is done, on SW:
copy tftp: flash:
cat3k_caa-universalk9.16.03.06.SPA_2 (Exact IOS name, in some cases in the end you might need to add ".bin"
Note: this might take several minutes depending on IOS Size.My case took more than 10 mins.
5 - in case if your switch is having two IOSes you need to mention from which IOS it will boot, so perform the below step for 3850.
config t
boot system flash:cat3k_caa-universalk9.16.03.06.SPA_2 (flash:exact_ios_name)
exit
6 - just to confirm on next boot what IOS it will take.
show boot system
7- Save and reload.
wr mem
reload
Many thanks and good luck...
Regards,,,
06-12-2018 05:03 PM
When you use "boot system flash:" you are running in bundle mode.Your switch was originally running in install mode. To run in install mode you need to install the software as outlined in the release notes. Have a look at the release note i attached in my last response.
John
06-13-2018 04:16 AM
