3850 Switch issue
hamza-ali
Hi Team,
I have an issue related to cisco switch with model WS-C3850-48P. Its become factory reset when we restart it...
its version sw-version:16.09.06
Switch Image: CAT3K_CAA-UNIVERSALK9 INSTALL. Please suggest
Thanks Team,
Issue got resolved to run this command in global configuration mode:
config terminal:
no system ignore startup config switch all
then,
Privileged mode:
copy startup config.
reload
8 Replies 8
Mark Elsen
 - @hamza-ali            It can't factory reset on it's own; post the full boot process
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
M02@rt37
Hello @hamza-ali
Please share you config-register value.
Best regards
Hi M02@rt37.. i have configure (config reg is 0x2102) when switch restart its come back to Configuration register is 0x142.
with zero configuration
Ok @hamza-ali
You perform a 'wr' before reload ? sorry for that question...
Best regards
Try also to add this command and test reload after modify also the config-regsiter value:
no system ignore startupconfig switch all
also see here:
https://community.cisco.com/t5/switching/why-sw-3850-loses-config-after-reload-even-though-config-is/td-p/2471639
https://quickview.cloudapps.cisco.com/quickview/bug/CSCui54490
Best regards
Mark Elsen
  - @hamza-ali         Checkout  https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/216850-configuration-register-equivalent-clis-i.html
    M.
Leo Laohoo
If the switch is in ROMMON, please post the complete output to the command "set".
Thanks Team,
config terminal:
then,
Privileged mode:
reload
