3850 WebUI will not log in
Could someone give me a few ideas on a problem that just started.
Just bought a 3850 12XS, updated to software to Denali 16.3.2.
Logged into the WebUI. Got in fine with the default username and password. Just browsing the pages. I must have changed something because when I tried to login later it says
"Wrong Credentials. Please Login again."
I didn't think I changed anything but I must have.
Is there a way to reset the username and password or figure out what it might have changed too?
I logged into the USB management port and found the lvl15 username and password but it still does not work.
20 Replies 20
I tried this also with different browsers. It didn't work for me.
so you can connect to via http or https, just can't authenticate?
That's the right work-around !
Thank you man.
Works (of course) even for http server:
config)# no ip http server
config)# ip http server
then the login working fine (one time).
It si an anomaly still present in 16.6.9
@lauri, Thanks
I am experiencing same issue, If I need to login via web then every time I need to disable and enable http server services on the switch.
Is there a permanent fix for this or not ?
Try adding the command 'ip http authentication aaa'
I can connect Via https and http. Login page will appear but will not accept the credentials. I have enabled http authentication for local user..AAA is disabled. looks like some kind of IOS bug. Its 16.3.3 denali. There some other memory leak issue also going on. I m planning to go for IOS Upgrade. Any other suggestions would be really helpful.
