10 Gbps module
asmlicense
Level 4
Level 4
Dears,
We have WS-C3850-24T-E device as core device and we need to purchase 10 Gbps SFP module.
To be honestly I confused with this datasheet - https://data.nag.wiki/Cisco/Datasheets/Switch%20Cisco%20WS-C3850-12XS-S.pdf
As I understood from the documentation we can buy C3850-NM-2-10G for our case. Is it right ?
2 Accepted Solutions
hi @asmlicense yes. this model support C3850-NM-4-1G, C3850-NM-2-10G modules. you can use any of them at a time.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
Good luck
KB
Joseph W. Doherty
Correct.  See the top of table 2 in @Kasun Bandara 's reference.
Good luck
KB
Joseph W. Doherty
