3850X switch password reset
Upenyu333_2
Has anyone tried to do a password reset on the new 3850X switch? I have tried the usual Hold Mode button for 15sec on reboot but thats not even interrupting the boot process.
Also these new switches come with a reset button at the back...what does that really suppose to do? I have pressed it but it has only managed to reload the switch.
PZ
5 Replies 5
Upenyu333_2
Kept trying and bang....so I kept holding the mode button for slightly over a minute and it finally worked. Now I have the usual switch: but now there is no flash:config.text anymore.
Any idea what the new procedure is anyone?
Glad you got it working.  The mode button serves a few purposes including resetting the switch back to factory default (wiping the config).  If you get into the dilemma again, below is a link to the clean password recovery method.
Password recovery on a 3850
https://supportforums.cisco.com/docs/DOC-35289
3850 Deployment Guide
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/deployment_guide_c07-727067.html
Thanks Richard for the procedure. It worked perfectly.Cheers
Did you do the "flash_init"?
Can you post the output to the command "dir flash:"?
Yes Leo I did. But the issue was the old procedure does not work on the new 3850 switches anymore. Thanks anyways
