4006 switch configuration
gururajan
I need to check the MAC address in each port of 4006 switch (Cat OS - 8.4).
Show port mac-addr <portno> command is not available in 4006 switch.
Can anybody help me out on this.
Guru
mahmoodmkl
Level 7
Level 7
HI
u need to use
show cam dynamic mod/port
Mahmood
Thanks for the reply.
But i think it will only show the learnt MAC address.
What we need is the MAC address of each switch port.
In 6500 / 4500 switches, you can see the Port MAC address using "show port mac-address "
Guru
