4451-X Basic NAT issue - router blocks return traffic, no ACLs
matthric
I have an Cisco 4451-X router which I am trying to get very basic NAT Overload to work on, I have stripped it back to the bare minimum and the behavior is very odd.
  • This is a double NAT scenario for lab purposes, the ISP router does NAT fine, all works well in the 192.168.0.0/24 subnet
  • Behind the 4451 any ping to the internet (e.g. 8.8.8.8) works fine
  • Behind the 4451 anything else (HTTP, DNS etc) makes it out to the internet OK, the response comes back through the ISP Router and hits the external interface of the 4451 and gets dropped (I have done packet captures on both sides of the 4451.
Topology:
PC (10.10.0.5) ------------> (10.10.0.254 on Gi0/0/1) 4451-X (192.168.0.254 on Gi0/0/0) ------------> (192.168.0.1) ISP Router (ExtIP) ------------> Internet
The config is shown here, I write erase'd the 4451 and put back the bare minimum commands - this should be super simple, I have configured NAT more times than I can remember...
Matthew
Router#sh running-config
Building configuration...
Current configuration : 1984 bytes
! Last configuration change at 20:12:38 UTC Fri Jun 9 2017
version 15.4
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
voice-card 0/1
no watchdog
license udi pid ISR4451-X/K9 sn*********
redundancy
mode none
ip tftp source-interface GigabitEthernet0
interface GigabitEthernet0/0/0
ip address 192.168.0.254 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
ip address 10.10.0.254 255.255.255.0
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface ucse1/0/0
no ip address
shutdown
no negotiation auto
switchport mode trunk
interface ucse1/0/1
no ip address
shutdown
no negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat pool NATOUT 192.168.0.254 192.168.0.254 netmask 255.255.255.0
ip nat inside source list 4 pool NATOUT overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 4 permit 10.10.0.0 0.0.0.255
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Router#
Philip D'Ath
Try this.
Remove:
no ip nat pool NATOUT 192.168.0.254 192.168.0.254 netmask 255.255.255.0
no ip nat inside source list 4 pool NATOUT overload
Add:
ip nat inside source list 4 interface GigabitEthernet0/0/0 overload
Philip D'Ath
Try this.
Remove:
Add:
I suspect the problem is that you made your NAT pool the same as your outside interface address.
Hi Philip,
This worked perfectly, thanks for your help - all the documentation I found referred to using:
rather than your method which works
Thanks!
Matthew
