Trunk on Capwap interface on 3850
I've a Cisco 3850 with WLC functionalities enabled.
I notice that there is a trunk between the switch and a capwap interface associated to an access-point.
I also notice that all vlans configured on the switch are allowed on that trunk.
How is it possible to permit only some specific vlans on that trunk?
How is it possible to tune the native vlan on that trunk?
Antonio
farcosre
I share you the commands tha you need for your switch
Switch(config-if)#switchport trunk allowed vlan ( vlans that you want to permit)
Switch(config-if)#switchport trunk native vlan (vlan that you want set aside as native)
Greetings!!
