4500 configuration question
gskatz
Is there a command that will show the port speed on all ports of an given module. not using sh int
example. Say I want to make sure all 48 ports on mod 5 are running 1000 full
appreciate the help
Bobby Thekkekandam
Try "show int status"
Switch#show int status ?
err-disabled Show interface error disabled state
inactive Show interface inactive state
module Limit display to interfaces on module
| Output modifiers
HTH,
Bobby
*Please rate helpful posts.
thanks the sh int status did it.
