4500 Sup V STP Instance
As per Sup V datasheet, it support 3000 STP Instance & as per my unerstanding, sh spanning-tree summary gives me the stp instance in any point of time
Apart from this, any other method/command is available to check stp instance
Br
"sh vlan br" could be pretty close unless you run MST.
