4500 supervisor swap
stephen jeffrey
Hi all, We have two 4500 chassis running as a pair. One of the switches needs the supervisor blade swapping out. I have received the spare and am ready to perform the swapout. Is it as easy as making a backup of the startup configuration and copying this back onto the new supervisor. I did think about having both running at once and failing over to the new one but not sure if this is a great idea as I'm not certain on the config to archive this, Any help or guidance would be more than welcome . Thanks.
Rejohn Cuares
Level 4
Level 4
The recommended way is to read the installation guide of your supervisor module. This will ensure that you wont miss anything.
Please rate replies and mark question as "answered" if applicable.
