4500 VSS
adamgibs7
Level 6
Level 6
Dears,
I am proposing a SUP 8E for VSS on 4500 , please confirm the license required for VSS on SUP 8E and 9E is enterprise services,
I have read the licensing  on the configuration guide but i didn't understood right to use concept
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-11-0E/configuration/guide/xe-311-cg/vss.html#94730
Please clarify
thasks
The only place I can find it documented is in the release notes.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_32143-01.html
Search for "Easy VSS".  It takes you to a table showing what is available in "Lan base", "IP Base" and "Enterprise Services".
9 Replies 9
balaji.bandi
If i understand correct  - Just to make note,
If this is new Setup - why not move to New Catalyst which has longtivity.
The steps if you already have VSS configured. If you building VSS you can apply the License and join to VSS.
BB
Philip D'Ath
I believe "Easy VSS" is supported in IP Base, and full blown VSS in "Enterprise Services".
Dear
Can you refer me to the document mentioning  that for easy vss ip base is enough and for full fledged VSS we need an enterprise License.
@balaji
it is an existing switch, in which we are replacing the sup6le
Actually that table shows VSS itself is also in IP Base.
Dear Philip
Thanks for the reply,
the release note are of Sep 2018, and after that there are no latest, all it is mentioned about SUP8E and no where for SUP9E so i hope all information mentioned for SUP8E also reflect to SUP9E,
so the conclusion is IP BASE is enough to configure Full VSS  features in switch.
thanks
You should be fine with IP Base. Both VSS and easy VSS are the same thing:
Beginning with Cisco IOS XE 3.6.0E (IOS 15.2(2)E), the Catalyst 4500 series switch supports Easy VSS, which enables you to configure VSS with a single command on the active switch and no action on the VSS standby switch.
Link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-6-0E/15-22E/configuration/guide/xe-360-config/vss.html#60764
In that case suggest to use Enterprise Services IOS, so you have also run some OSPF, if this acting as CORE.
BB
omaali
SUP9E supports VSS starting IOS XE 3.10.0 with minimum requirement of IP base License. Will get that added on the data sheet. SUP8E provides 8x10G ports with 80G of uplinks bandwidth where as SUP9E provides 4x10G and 2X40G uplinks with 80G of uplink bandwidth. The uplink ports on SUP9E can be mixed and match according to the preference.
