4500-x / 4900M Vrf Leaking
Hi !
Does the 4500-X or the 4900M supports VRF rt import/export ?
i need it to create a VRF Leaking between Vrfs ...
Thanks !
Rahul Kukreja
Here is the datasheet for 4900M :
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
you may search for VRF and it looks like Enterprise Services image supports VRF Lite
For 4500-X :
http://www.cisco.com/en/US/prod/collateral/switches/ps10902/ps12332/data_sheet_c78-696791.html
• Cisco IOS XE Software IP Base:
Includes all Layer 2 features and some basic Layer 3 features.
• Cisco IOS XE Software Enterprise Services:
Upgradable with a Software Activation License (SAL); supports full Layer 3 protocols and advanced features such as complete routing scalability, Border Gateway Protocol (BGP), Virtual Routing and Forwarding, Policy-Based Routing, and so on.
- HTH
Rahul
Leo Laohoo
All 4K support only VRF-Lite.
The "smallest" Cisco Catalyst multi-layer switch that supports full VRF is the 6500E Sup7E or ME3800X.
6500E Sup2T also supports full VRF.
