4500E vs 6500E
I'm looking to upgrade our Core switches from the classic 6500s to an E-chassis switch.  It seems that the 4500-Es are beefier than the 6500-Es but from experience and a production standpoint, which would be better suited for a core environment?  We can't move to the Nexus platform; at least not yet.  We would need Gig ports and uplink ports that would support both 1/10Gbps uplinks.
Thanks!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, the 4500-E isn't really "beefier" than a 6500-E, but to maximize the 6500's performance you need to carefully select components.
Either can be a good core device.  The 4500 series should be less expensive.  If you use a 6500-E, and you've been using 6500s, you can reuse other components, but again, you need to be careful what you use if you want maximum performance.
For a core device, instead of a 6500, you should consider a 6807 or 6880.
For a core device, you might also want to consider the 4500-X.
yes 4500-X can be a better and optimal choice as you are moving from old 6500s .
Data sheet for 4500-x Vs 6500E
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/data_sheet_c78-696791.html
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/data_sheet_c78-708665.html
